Drying Towels Recommedation
RacewayAutoSpa
Iselin, NJ
Hello everyone! I just purchased my first full service car wash in Central NJ. Can anyone recommend good drying towels? The current owner did not recommend that I continue to use the ones he currently has since they do not absorb very well. The crew also complained about them. Does anyone have a good recommendation for me? Thanks!
The ones we use for our touch free / self serve wash are the bulk box from ERC wiping. They are recycled so they dry well w/ no break in peeriod.
They might be too low class for your wash though.
rph9168
Carwashguy
Atlanta
Microfibers are good but also expensive. I think bulk towels from any of the suppliers do a good job at much less cost. I would consider using microfiber towels on interior windows if they can be kept separate.
The key is to make sure towels are kept clean and employees are taught how to properly fold and use towels. We taught our employees how to fold the towels so each one actually had 8 clean sides when used correctly. To this day it bothers me to see an employee just grab a towel, bundle it up and start drying. Even worse is to see someone throw a pile of towels on the vehicle's hood as it leaves the conveyor. Professional car washers should be taught to do things professionally - not just haphazardly.
robert roman
Bob Roman
Clearwater, Florida
It is crucial to color-code and separate towels by function to avoid cross-contamination during laundry from silicone, wax, brake pad dust, etc. which ultimately leads to smears and streaks on paint and window glass.
Carwash towels can be obtained in economical quantities from suppliers like Towels by Joe, etc. that advertise in the carwash journals. Follow OEM's procedures for preparing or seasoning towels before using for production.
Slightly dampened, heavy weight cotton “soaker” towels (i.e. blue) can be used to dry body panels of vehicles as they exit the dryer producers (side drying).
On finish line, medium weight cotton soaker towel (green) can be used for final detailing (wipe down, door jams and console).
Medium weigh, dry, soaker towel (white) would be used for armor all interior and cleaning rims.
We used a light weight hospital grade linen towel, dry, for windows (red).
The reason for recommending folding towels in 8ths is it’s conducive to process.
For example, “four-pass” and “box and fill” methods are commonly used to final detail cars and clean windows.
Four-pass is a technique for completing all the steps in final detailing a vehicle within four spans of the vehicle's length.
Box and fill means apply solution and then clean window by making a box moving in clockwise or counterclockwise manner and then fill-in moving back and forth to clean the center of the box and then repeat to polish dry, folding towel over and over to clean side as you move along.
Washmee
Fullservice Tunnel
Canton, Ohio
I've been using Towels by Dr Joe for over 20 years. For body towels I use the Ambassador ll towels and prefer dark colors like black,blue or charcoal because they never look dirty.
.http://www.towelsbydoctorjoe.com/theambassadorincolors-1.aspx
For Windows I use lint free micro fiber towels. They are similar to the towels you get when you buy a pair of reading glasses, but much larger.
http://www.towelsbydoctorjoe.com/largerlint-freeglasstowel-12pack.aspx
I am a firm believer in buying quality towels. They last longer and perform better if properly taken care of.
Ronkonkoma, NY
Washmee is correct in buying high quality towels, buying budget towels will end up costing you more as they will break down and require replacement at higher rates. Cotton although a mainstay in the industry for years have been slowly loosing ground to high quality microfiber replacements.
I have used microfibers exclusively over the last few in my full service wash. After you make the change you will tend to stick with them the for life. Break in cycles are minimal (1-2 washes) and using a Uni-Mac 202 you can quickly and efficiently process towels for a car wash front line delivering a clean and lint-free car. There are many types on weaves and blends to choose from when selecting a towel. You should get some samples and test them.
Here is a breakdown of some of the towels available that I used.
http://gliptone.com/towels.htm
PM me with any questions.
Bobby
