Ds 500
so I have a ds5000 that those two passes a pre soak 1pass of high pressure from the rear to the front one pass of triangles and then a passive high-pressure front to back clear coat, again I'm not getting the high pressure pass of clear coat.there are 4 demo valves on the bench one is power blast nozzles one istop oscillating nozzles. I cleaned all the demons out about a month ago when this happened and it hasn't been a problem since until nowis it most likely the dema valves or could it be Diagnostics
