Dual Boom Conversion to Single Boom
I would check and see if you can replace just the spindle with a standard one and remount just the high-pressure boom to it.
The only reason I do t want to do that is because the through bolts that hold the spindle are underneath my ballasted rubber roof. I need to reuse the spindle to minimize the amount of extra work for the modification.
Out of curiosity, why do you want to get rid of the dual boom setup? Is it to gain more overhead height?
I have the Dual Wall Mount Boom like you linked to. The pivot holes are drilled at an angle so the booms always return to the wall. I think this design helps from making a tangled mess out of the hoses. I have FB and Tri-Foam on mine...
No, not really. More often than not, the hoses get tangled quite easily. The way the foam brush boom is manufactured, there are gaskets that end up dry rotting and leaking solution down the spindle. The gaskets are roughly the same price as the dual mount and I wouldn't have to mess with it again...
What i did once is drill and tap the foam brush hole and ground it so the spacers would fit back on and removed the foam boom section on the unit.
