When a customer is finished using a HP option, I noticed the electric motor continues to run for about a minute longer, it does stop. Even when the customer is using a LP option, or the timer has expired. The water valve closes like it should, so there is no water running through the pump, but the electric motor keeps spinning. It does stop after a minute or so. Is this a sign that the timer is going bad?
