Kevin James
- Joined
- Nov 15, 2007
- Messages
- 562
- Reaction score
- 32
- Points
- 28
I got a call from a customer who said while using the bay it just stopped. He said the display was blank and nothing worked. I asked him what function he was using when it shut off and he said he was using the Foam brush. When I got there the 24 volt breaker for the low voltage system was tripped. I reset the 24 volt breaker and the foam brush worked fine for about 10 minutes before the breaker tripped again. Only the Foam brush causes the 24 volt breaker to trip. I didn’t have a volt and amp meter with me so I went ahead and changed the easy things first the timer both of the foam brush solenoids. Now what should I be looking for and how many amps should the foam brush system be drawing?
