Electrical & Plumbing for replacement IBA
washregal
I am replacing an in bay automatic - taking out a Pro Navigator and installing either a Washworld Razor , or a PDQ Lazer 360 - Looking to perhaps hire my own plumber and own electrician.
What detail can I or should I give them that they can give me an estimate on for both plumbing and electrical work? I am also looking to install New RO and Softner as well as paystation - Thinking that the distributor I choose will install these - Electrical would be primarily for the IBA. Has anyone had experience in this on how I can guide the plumber and electrician of the best way to give me a direct quotation?
If you go with the Razor, their electrical prints are pretty good. Any electrician would be able to quote from them. Not sure about PDQ, I assume their prints are just as good since they used to be the same company.
Good idea to check other sources for the install. Check with the distributor though. Any decent one will do everything you noted. Outside quotes help in keeping his quotes more realistic.
