Festoon Roller Lubrication
UndertakerII
Canada
What kind of maintenance/cleaning/lubrication does everyone do as far as the festoon rollers go on a Laser 4000? I haven't seen or had any issues but would like do whatever preventative maintenance to keep it that way!:eek: Thanks. Kevin
tdlconceptsllc
NC
Spray WD-40 on the festoon rollers every two weeks depending on usage of your site I do it to mine and works good it also describes this in the PDQ Manual and on festoon rollers inside the bridge also check air in tires around 26-30 psi and grease machine with Arctic Jetlube. I buy WD-40 in bulk and put it in a spray bottle makes it easier on a ladder. hope that helps
