Bubbles Galore
The fill tank for my self serve bays is continuing to overflow and it is driving me nuts. It is a fairly new valve (less than a year) and is leaking on the backside a steady stream of water even when the bays aren't calling for water. I closed the feed valve and opened it back up slowly and everything was good until the tank had to fill up again. Any ideas on what might be causing this? I definitely don't want to have to replace the valve if I can avoid it.
