Flo Jet would not work and my guy swaps it out. New one wn't work. Gets frustrated and calls me. Star with air source to solenoid, thru solenoid, out tubing to flo jet and finaly find that when he swapped out the pump he used the quick disconnect for the brass air line fitting on the pump which is also a valve and was broken so it di not open when inserted in the pump.
First time it happened in dozens of pumps at all locations in several years.
As coincidences go, it happened a second time (another location within a month) easier to find this time. had explained the issue to all my guys as soon as the first one happened but the guy at the second location then told me he really did not understand what I was talking about until it happened.
Just so you can learn gfrom others experience.
