My flow jet pump that runs my soap will cycle intermittently when the car wash is not being used. Anybody have any experience with something like this happening?
Check to make sure that the input and output lines to the floject are secure. If they seem okay could be a solenoid that isn't completely closed. Check in your bays to see if chemical is dripping out of brush or wand...whichever soap you are talking about. If you find soap dripping clean out the corresponding solenoid and that should fix the problem. Good Luck.
Should have also mentioned to check the connections at the solenoid (in and out). I've had that issue a few times. Anywhere there is a leak might be causing the floject to pulse.
