Flojet air pump signs of going bad
Hi all, when is the time to change these flojet pumps( pic attached). This one leaks air from the hole in its button sometimes. Or after working for few minutes the sound of it changes… i know its a rather cheap part and easy yo change but wanted to see your experiences please.
I made an air dryer for my air compressor, and haven't changed out a FloJet since.......
How did you make one? We installed a refrigerated dryer recently on our remodel so hopefully pneumatic parts last longer.
Thanks all, created a little procedure to how to change these pumps:
Flojet pump change: (foam brush, tripleshine, presoak, tireCleaner)
Step 1: empty foam brush hydrominder tank
Step 2: shut off air regulator to the pump
Step 3: run a bay foam-brush(or whichever function changing pump for) to empty the line completely and product pressure goes to zero
Step 4: un click the 3 input lines in the button: air, chemical in, chemical out
Step 5: unscrew the pump from the wall and remove the lines from the button of the pump, and the pump itself
Step 6: with the new pump, add the 3 lines in the button, and screw the new pump to the wall
Step7: add chemical to foam brush hydrominder and turn on the air regulator to desired pressure
Step8: test the foam brush in all bays
I should have kept my opinion to myself. Within 2 hours of posting, my FloJet quit after over 10 years of service. Ha. That thing doesn't owe me a dime.
Anyway...
I purchased a transmission oil cooler, and mounted it on the air compressor. I route the hot compressed air into the top of the cooler, and run the bottom (output) into a self dumping water trap. I have an electrical fan draw ambient air across the cooler whenever the compressor is running.
This causes the hot, moist, compressed air to cool, which in turn causes the moisture to condense. The cool, dry air is then routed into the tank.
I haven't had a single issue since installing.
My ARO pneumatic pumps run without freezing up now.
I'll try to upload some pictures soon.
My flojets have a check valve that is part of the brass fitting that clips in to the pump. They can go bad and you have to be careful about that but once you un clip it shuts off air, So with a valve for the liquid supply we just close that, unclip all 3 hoses from the old Pump, attach the new pump, open that valve and we are back in operation and then un mount old, and re mount new. So, old is out and new is in and operating - well under 30 seconds - could be under 10 seconds if nothing is stuck or hard to get to.
I put a Ingersoll Rand refrigerated dryer (about 1K) on my lines to protect some expensive SMC air cards on an IBA, but Flojets definitely benefited, Even with multiple moisture traps I was getting maybe six months out of flojets. I think I have changed one out in three years. Also air cylinders on my water wizard are lasting a lot longer. Not saying the math works out considering energy usage but it's nice having dry air and make the site more reliable.
It takes me about 2 minutes to change a Flo Jet pump. I have a ball valve on my chemical tank that I close and a ball valve on my air supply to the pump that I close and the Flo Jet pump is mounted on a quick change bracket. https://www.kleen-ritecorp.com/p-2092-flojet-fpk209821-mounting-bracket.aspx like this one. I don't have any moisture separators on my air supply to my only Flo Jet pump and they last a long time, years.
I have found that when a Flo Jet stops working suddenly, you can remove the 9 screws at the base of the unit (after disconnecting it) and 9 times out of 10 a bunch of liquid will come out of the chamber. Since the liquid is not compressible, the diaphragm hydrolocks preventing normal operation. When all liquid has been removed, reassemble and it will work as advertised to get you through in a pinch. This is your notice that it's time to replace it immediately.
