I have a question regarding my floor heat. I have two tankless water heaters with circulation pump that provide the heat for my bay floors, heat for the automatic bay, as well as some of my exterior concrete around my change machine. The set up works great.. my only issue is now that I need to dial it back as it is set up to run constantly. My question is where would the best place to put a thermostat to where it will keep the automatic bay 40+ degrees, keep the self-serve bays clear of ice, but also not run constantly. I have a weepmizer connected to a probe that’s on the north side of my building but the system would still run constantly if connected to it. I’m thinking it wouldn’t have to go in my automatic bay.
Anyone have a similar setup or thoughts/ideas?
