A audiosnow46 Member Joined Feb 13, 2011 Messages 63 Reaction score 0 Points 6 Location Rapid City, SD Apr 4, 2011 #1 I have 2 self serves that have foam brush chemical leaking into the weap only when someone uses the foam brush. I have changed a couple of check valves but it didnt seem to help. Anyone else know what it could be?
R Randy Well-known member Joined Sep 5, 2007 Messages 5,913 Reaction score 2,298 Points 113 Apr 4, 2011 #2 I just had the same problem last week. You've got a bad check valve in the foam brush system weep system. You must have changed the wrong check valve.
A audiosnow46 Member Joined Feb 13, 2011 Messages 63 Reaction score 0 Points 6 Location Rapid City, SD Apr 4, 2011 #3 alright ill check again... thanks
