Expresswash3
Greetings..I'm having an issue with the foam brush on my Coleman unit..It keeps blowing the low voltage fuse..Its a 4 bay unit..and its driving me crazy..Ive changed the motor..thinking it was bad..installed new motor...worked fine ..then fuse out..removed procon pump..motor ran fine..installed blown fuse..installed new procon pump...worked great..couple days later..blown fuse..Could it be a bad solenoid bank?..I was there this am..fuse blown over night replaced fuse..tried it on bay 3..blew the fuse..replaced fuse..tried bay 3 again..worked fine..tried every bay and would not blow the fuse..HELP..
