What does it look like? Is it so thick and foamy it's not flowing or is it watery and not foaming? Like 2Biz said, the mixture could be wrong from a failed Hydrominder foot valve, clogged tip or the valve itself not flowing enough water to draw the chemical, or your softener may not be working.
i will try that but i think i am getting alot of soap because the water is really blue . also i am getting to the bottom of the pail could that be a reason too![]()
Andy, I had a situation like this just a couple of weeks ago and I've never had it happen before. I am using Kleen-Rite Bubble up for the foam brush. The foam started to get really thin. I did all of the above to no avail. I had five gallons of mixed soap in a 15 gallon drum and I poured it up and mixed a new batch. Problem solved. For some reason the soap just died. It was like you said, lots of color and everything seemed to be working but it just wouldn't foam. I thought it was a isolated case.Thanks for the replys i did not go in today will try to fix tommorrow![]()
I don't want to hijack here but I have a similar problem with my triple foam but only in one bay. I was certain that it had to be the air solenoid. I changed the stem and coil but still just colored water. No sign of air at all. If I had a broken air line wouldn't I be able to hear it?
When I remove the air hose, chemical comes out there???????????????
