Foot valves
For my suction hose I use 3/8" polytube and the 1/4" footvalve will fit inside the tubing nice and tight. If you're using the 1/2" hose I believe the 3/8" footvalve will push into the hose. I would also secure it with a zip tie or stainless hose clamp.
I started using the stainless ones about 6 months ago. No problems yet. And they do have check valves in them.
Gray for preasoaks tire cleaner and harsh soaps the BLUE is for waxes and triple foams don't ask me why if you switch them you will have problems learned the hard way
