Fragramatics timer wireing help.
rossallen768
Trying to replace idk ltt8 with dixmor led7m. I can't get it all to work either the coin, bill acceptor works and the timer starts counting. Or the vac fragrance switch works toggling the price and time but then the bill,coin acceptor stops working. Anyone know what I'm doing wrong
Keno
Call fragramatics, they are helpful and know their stuff
ram south la
KleenRite carries the GT200’s that are direct replacement for old IDX LTT units. Same wire harness plug. Easy to upgrade from old LTT.
rossallen768
To answer my own question. The vac selector harness is a switched common and the timer needs 24v hot applied to toggle functions, added a relay and a hot wire to the relay now it all works as it should. May not be the right way but it works.
