fuel bowser pull-up thingi
JustClean
Hi all,
I've got a fragrance & shampoo machine and after so many years I am getting sick of always picking up those hoses from the ground. Now I thought of getting one of those "pull-up pipe whatever thingi" (you can see them on some old petrol pumps). It is actually a long vertical pipe with a weight inside which is attached to a rope that comes out of the top and is then attached to the fuel hose. If you pull the hose the weight goes up and if you let go the weight pulls the hose back. Does anyone have an idea how it is called and where to get it? I tried Google but was not successful. Thanks.
Hi all,
Found it. Thanks. It's called "Fuel pump hose retriever"
