Jimi
Hi. I have a WW 2 that binds up so badly on its way home that it will raise the follower wheel off of the rail. This happens at the same spot each time and it happens on the passenger side. It's like the passenger side gets so far ahead of the drivers side that it creates a bind. This does not occur in reverse. I have replaced both wheels and bearings on the passenger side. The wheels and bearings I took off appear to be fine. The wheels and bearings on the driver side also appear to be in good working order. I have replaced the bearings on the gantry that attach the articulated arm to the wall. I am lost and in need of some insight and suggestions. Thanks in advance.
