We are trying to get our three self serve bays back up and running after an insane remodel and it has been a struggle. Almost everything was torn out and put back in a different spot. I wanted to make sure the pumps were still good after sitting all those months so I hooked up the city water and jumped the solenoid valve and motor starter on bay 1. (we don't have the meter boxes wired yet) The hot water gravity tank is not hooked up yet. The pump started out fine but chattered and lost pressure when pulling the trigger in the bay. It acted like it was starving for water so I pulled the mesh strainer near the pump inlet to check for volume. It was only getting about 2.5 GPM and with our tip and pressure setting it would need 3.5 GPM minimum. I tested the other two bays for volume and they were a little better but nothing over 3 GPM. I pulled the plunger out of the solenoid valve and got maybe 3.2 GPM out of one. Also, I pulled all the plumbing off the solenoid valve all the way past the mesh strainer and didn't see any issues. The feed line to the solenoid valve is a 3/8" OD poly tube and when removed tested about 5+ GPM. The GC valve is only a 1/4" with a 3/16" orifice and I thought that seemed small. At that point, I was really confused about why Super Wash built it that way and could not understand how it could have operated properly all those years. I decided at that time that I was smarter and would buy larger 3/8" solenoid valves with 9/32" orifices and replumb all the 1/4" fittings to all 3/8". Today I got the valves and fitting so I redid bay 3, turned on only the solenoid valve, and was happy that I was getting about 4.4 GPM past the mesh strainer. There was water all over the floor and I tracked it down to the gravity tank inlet so that check valve is bad. I checked the other two and one of them is bad too but I don't remember before having the gravity tank level rise when someone was on rinse. Then I thought about how it may have worked before. The solenoid valve is a little undersized and the pump draws the extra water it needs from the gravity tank. If the check valve leaks a little, it will not back up into the gravity tank and may never need to be replaced. Are they the geniuses and I am dumb for re-engineering it?
