The Scan
Coin 303 says it off sorts the smaller
coins. Our
coins are 90 % quarters so off sorting quarters does not make since. Can it be set for quarters and the dollars just pile up and then be removed after the quarters are gone. Will this cause a problem? Is there a better solution?
JimT
How long have you been using dollar
coins? Are you using gold dollars exclusively? You shouldn't have 90% quarters with d/c's.
I currently use both and .980
tokens and have found it easiest and probably fastest, too, let the 303 do the sorting. I drop into buckets rather than bags. I have recently begun to batch wash the
coins before sorting. I'm not sure the fed appreciates the effort when I occasionally deposit quarters, but the counter, the
changers and even the customers notice.
