I have a JC Frag/Vac that is giving me fits trying to figure out the issue with it. One of the fragrances is not spraying and I can't figure out why. It is the one all the way to the right, so the bottom coil of the 3. I have tried replacing the coil, switching the coil with the middle selection, cleaning out the stem, cleaning the barbs to make sure they are open and also the making sure that there is no obstruction under the stem. It is not sucking the fragrance out, so it is not on the outlet side. Any suggestions on what else the issue could be? The other two selections work perfectly fine and the coil and wiring both work when paired to a different selection, so it is not the coil, button or wiring.
Thanks.
Thanks.
