Help wiring a vacuum 94000 single vacuum
Wasking
Does any one have an idea how to wire new Dixmore LED6 on to the vacuum?
I have the schematics for the DIXMORE but the wires coming from the vacuum I have no idea which is which.!
The manual is here. but the wire color code on the dixmor timer is different than what coleman uses. The harness itself is interchangeable. You can unplug a coleman timer and plug in a dixmor and it will work. So what you need to do is look at the schematic and convert the wire colors from one harness to the other harness.
Basically wiring the timer is simple and you will have multiple unused wires. - It's got to have 24 Volt to power the timer and the timed output goes to the mercury relay
The horn is located under the removable shroud in the front of the vac. Looks like you need to connect the wires on terminal 3&4. The horn is DC so make sure you hook up the positive and negative terminals correctly.
