High Pressure hose-
Skyler
What is the preferred hose to replace. The present hose is rated at 3250 psi. would a standard hydraulic hose
be able to be used and not break down from chemicals going through it. The hose is 35 ft and not
sure of the options that would be best for the continued flexing.
What are you using th hoe for? For SS and Prep I use the single wire HP Hose from KR. I order lengths I need with swivels and Hose saver on one end. Cost not so different than ordering bulk hose, and ends / swivels separately. IMO Hydraulic hose is too heavy and tiff. Due to varying length I do order that in bulk with ends separately and have a swaging tool .
