Home plumbing and hot water supply
At the risk of sounding ignorant, I will pose the following query.
Do I need a hot water storage tank at home?
I have ample hot water supply for showering via my HB Smith Oil-fired furnace with 'on demand' hot water. However the system falls short for filling the tub in the Master Bath with scalding, hot water (which is what I require for a proper bath).
All the never seize I've been using and subsequently wearing needs a good,,extended 110 degree F soak to emulsify!
TIA; wax:D
Since it's "on-demand," can you just reduce the fill rate to get hotter water? If not, a storage tank would be a solution, but it would defeat the whole purpose of an on-demand system.
