Homemade Dema 294
Valkyreel
London ohio
Does anyone have plans or a diagram for a homemade foamer (think it's called air injection) like the Dema 294? Thanks.
Valkyreel
London ohio
For what type of application?
Thanks, good question. It's for a foamy brush system for my personal use. I don't own a carwash, so I don't have pumps and mixing containers to just add a tee fitting or pvc foamer. I need the whole assembly. The Dema 294 looks quite simple, maybe it's easier said than done or maybe I'm missing the point of what the 294 is used for. That's what I'm here for. Thanks for any help.
Valkyreel
London ohio
An injector is a fairly precise item, and it needs to be adjustable for chemical use whether it's with a needle valve/screw or with tips of varying size. It draws the soap with the flow of water. Without an injector you'll need a pump, and you also need an air compressor.
Valkyreel
London ohio
That's the info I needed. Thanks.
Pump : no
Garden hose water: yes
Air compressor: yes
Dema 294c: ordering tonight from kleen-rite (hey, that rhymes)
