My automatic bay's Cat 3535 started making a horrible "knocking" sound. It almost sounds metallic. Worried that I had either a bad bearing in either the pump or the electric motor I started troubleshooting. The belt (cog style, tripple grooved) is original, but 17 years old. It looked fine, but maybe slightly loose. I tighten it up a little, but the noise remains. I then spray the belt with belt dressing, and the horrible noise goes away. (It can't be a bearing...correct?).
Anyway, that was last night, and the bad noise is back. Can this belt which appears to "look" fine....actually be the problem?
It's just hard for me to believe that you could get a metallic sound from a bad belt?????
