How do you check for leaks with air on floor heat?
Buzzie8
Pittsburgh, PA
I made a repair on my floor heat today and it seems to be working fine. I ran the pump and no sign of a leak. In a previous post, I was told to put about 10 PSI of air in the system and see if it leaked before redoing the concrete. There is a tank attached near my boiler that has what looks like a tire valve attachment welded to it. I am assuming I attach my small compressor to this and set the regulator at 10 PSI. Is this correct?
lag
Middle of Iowa
That's your expansion tank. Don't hook up there.
Our system is a multi zone system,and I will isolate the run,and install our air on one side of our teco pump,and put a gauge on the return line. I like to do this when doing a large pour.
If you have run the pump,and you only need to do a small repair you should be fine.
Feel free to PM me you contact info,and I would be glad to clarify any info.
robtl
central Ky
central Ky
If you are just testing for a leak on a repair dont add air to the already water filled system, test it by pumping the system with the water you have in the system.
If you are installing a new system and have not added water then put a air test on and leave it on until ready to charge with antifreeze. dont let the air pressure fool you, a completly tight system will vary on pressure over time with temp. changes. hotter the temp the higher the pressure will climb and drop on temp drop.
Buz,
I agree with robtl. Air during initial install or if you have to drain to make the repairs. Otherwise the specific leak should be revealed with the water. At this stage I would be very cautious about upping the pressure more than normal operationg pressure to test for leaks because some leaks could actually be created.
MJ
