Does anyone know how many amps a typical 2 motor vac draws at start up and while running? Thanks.
Even though wire to Vacs can be rated for direct burial ... I think using non corroding conduit is always a better long term choice.I'm sure it got wet, that's what happened a few years ago when I changed out all the lines. I was able to pull through the same conduit, I'm sure there is a break somewhere letting water in. I knew 10 gauge would be ok, unfortunately I meant to say it's 12 gauge wire running to the vacs. Think it would still be ok to run 2 vacs on that same wire?
That's what I have and have always been told.For a 3 motor vac what would you guys suggest? 30A with 10 ga?
Yes that's the requirement I have 3 motor vacs & that's what fragramatic requires.For a 3 motor vac what would you guys suggest? 30A with 10 ga?
Yes, IIRC you are not supposed to run a circuit over 80% of rated capacity, so you're supposed to limit a 20 amp circuit to 16 amp load, etc. So your next logical step up from a 20 amp with 12 gauge wire is a 30 amp with 10 gauge wire.For a 3 motor vac what would you guys suggest? 30A with 10 ga?
The wire probably got nicked while being pulled, otherwise it should survive fine in water. Worst case scenario, something shifted and broke the conduit and severed the wire, in which case you won't get new ones pulled through.I'm sure it got wet, that's what happened a few years ago when I changed out all the lines. I was able to pull through the same conduit, I'm sure there is a break somewhere letting water in. I knew 10 gauge would be ok, unfortunately I meant to say it's 12 gauge wire running to the vacs. Think it would still be ok to run 2 vacs on that same wire?
Except that most areas of the US don't allow wires to be "direct buried" in a commercial environment.Even though wire to Vacs can be rated for direct burial ... I think using non corroding conduit is always a better long term choice.
The length of the wire run from the breaker also takes part in determining the wire gauge.Usually 15 amp breaker for 14 ga. 20 amp for 12 ga. 30 amp for 10 gauge.
That's what local code is for.There are other technicalities & exceptions such as too crowded boxes, lower quality wire & insulation of specific same gauge wire etc.
I'll probably just tie the 2 vacs together for now as I try to troubleshoot. Stupid junction boxes on the way to this vac are under other vacs and I can't get the bolts loose to lift those vacs and access the junction box. I didn't have issues pulling wire in the past and there were broken wires underground, so getting nicked is probably what happened.The wire probably got nicked while being pulled, otherwise it should survive fine in water. Worst case scenario, something shifted and broke the conduit and severed the wire, in which case you won't get new ones pulled through.
I have seen (many times) two vacs running on 12 gauge wire on a 20 amp breaker without a problem.
Just ordered a can from Amazon. Will give her a shot! Would be awesome if it works. Thanks.Try some CRC "Knock'er Loose" on the bolts. I picked some up the other day, and it works better than anything I've ever used before, including PB Blaster. Everything I've used it on came loose easily and immediately.
