How to clean powder coat paint equipment
Let'Er Buck
Wyoming
Does anyone have any ideas or products to clean powder coat paint? Our equipment is looking a bit used. We have used Klean Wall with a 1/3 third Klean wall to 2/3 water mix but isn't cutting it very well with out a lot of scrubbing. That's not a problem except where the hoses and cylinder and etc are in the way.
Try using it straight. It seems to work better if you apply it to a dry surface.
Robert Bailey
Marietta, GA
very true ...key dry surface and let it sit like the directions say, dont spray and wash off right away.
I like to wet the equipment with the product then use like micro fiber towel to do once over making it even so to say.. keep towel wet with solution not water.. then spray again let sit while working on the rest.. then when finished wash it all off. I dont need to scrub anything.
