UtahYoutubeGuy
There are many previous questions and discussions around Nayax and how to set them up to run on different machines primarily in count up mode but I also offer a multi-price structure on my vacuums and token vendor. Nayax has made some significant improvements to their online dashboard that has simplified the Pulse settings and makes it super user friendly. Its called the "Pulse Wizard"! You can find it in Nayax Core if you go to the following.
Machines > Select Device > Settings > Pulse
There are 4 different pricing modes. Pay-As-You-Go = Count Up and from there it walks you through exactly what your Min. and Max. charge will be as well as how much to charge on your time. i.e. My settings are $0.05 every 4 seconds or 75 cents a minute.
Also if anyone is looking to buy Nayax devices here is a discount link and code:
Code: Revestor
Link:
https://nayax.pxf.io/c/4298119/1454672/15225
These are affiliate links which means I will get compensated if you use them but its also the best discount you can get and also the coolest readers as well.
Code: Revestor
Link:
