The one Hypro pump that I left in the wash i put back on line last year seems to have developed a problem. This is a D&S pump stand, the rinse comes from a tank mounted above the pumps. Soap uses hot water coming in under city pressure. there is a large check valve under the tank (one for each bay) I suspect that is my problem and I couldn't find the one I replaced needlessly last year so have to order. Also noticed on this pump stand the rinse feeds through a T below the pressure releif valve, so exess pressure dumps into the gravity fed line. My three other bays use a long hose that makes a loop before reaching the pump. this bay has about 6" of hose. Could there be too much turbulance so close to the pump? It was working fine and started pulsating while I was washing down the bay. It does pump some rinse water, just not full pressure and not steady so if it is the check valve, it would have to be restricting the flow but it is not stuck. It holds the water back when I take the hose off. Now I wish I had tried the longer hose before I left the site tonight. I also wish I took a picture as my fingers are getting tired trying to come up with a thousand words instead... Am I overlooking anything else to check? TIA.
