toddmullens
Is anybody that's using the Hydra-Flex chemical dispensing system having issues with the booster pump overheating on very busy days? We have the setup with a spare booster pump with the quick connect fittings to switch pumps quickly, but we had to switch over the pumps seven times in the span of a day just to be able to dispense chemicals. Very frustrating to say the least and it says nothing about this issue on their website. I know another group of investors with many tunnels and they experience the same issue. There has to be a reason or a solution to this issue. The pump bypasses back to the inlet and on busy days, the water gets so hot that the thermal relief valve spews water everywhere. The motor will then either trip the overload or just stop running which is weird because the manual for the pump states there is no internal thermal overload on the 3 phase model which is what we have (only the single phase model has internal thermal protection). Anybody have any ideas or tips to remedy this issue?
