It could be that you don't have enough water flow into the hydrominder. I had the same problem when I added a couple units on the same water supply as my existing units. I ended up having to upgrade my supply from a 3/4" to 1-1/4".
Either that, or you are sucking air on a hose, or thread connection on the chemical line.
