Do these act as a 24v or 120v relay for the LP functions?
And is there a hot and common terminal for each bay? I can't tell by looking at the picture and the IDX website says Under Construction, so I can't get any information from there.
Yes they are essentially a single pole relay, powered by 24VAC. IIRC common from each bay goes to the little connections 24 V hot goes to one of the big terminal. I think all bays have to derive 24V power from the same source. They are commonly used to power procons, or other electric pumps. They have a 20 amp max rating, but if the motor shorts it will take it out. I have fused the output in the past, I prefer to use them to power contactors.
