Injectors
fivebucks
wisconsin
Anyone have any problems with chem flex injectors?? Suppose to be corrosion resistant.
Thanx
DiamondWash
Des Moines, Iowa
I take it you are useing them right now or or you just asking the question if they are corrosion resistant? I am current useing them and have had no problems with them.
fivebucks
wisconsin
Pre soak injectors (my) are always corroding...high/low ph....heard of these Chemflex injectors that are supposed to be corrosion resistent...just wondering if anyone had any experience with them...
ken-pro
Equipment Distributor
Kitchener, Ontario
fivebucks:
We have been using the ChemFlex Kynar plastic injectors for about 2 years now on our Washworld equipment - They are definitely better than the original SS injectors. My low PH presoak was killing SS injectors in 3-4 months, Now I can get a year out of a set of plastic injectors. The SS portion of the ChemFlex injector still corrodes with time, and a year is pretty well the max expected life with low PH. They seem to last much longer with high PH chemical
One note - Make sure you test draw rates and titrate after changing to them - They seem to require one larger orifice size to draw the same amount of chemical as the SS injectors.
fivebucks
wisconsin
Ken;
Thank you very much...will check on availability in some of the catalogs...again thanks..assume they will work on PDQ LaserWash 4000
