IO cards for ww 1.0
Cal-Redwood
Salt Lake City, Utah
lag
Middle of Iowa
Have you looked at eBay for used I/O cards? I purchased some AB used parts there and have had really good luck. I only purchase from USA sellers. I get them in and just install,and let it run putting the card I took out into our parts stock. I got one output card out of about 20 that had a one output that didn't work. Easy return. I paid around 25 -30% retail. I've never purchased any omron however.
I have also never used the site you linked. .
Be patient and you can get them off ebay for a good deal. IO cards rarely give you a problem. I have four coleman units and between all of them I might put one on every couple of years.
As ridiculus as this sounds, you might could pick up an entirely used water wizard off ebay for few thousand. Then you would have spare everything!
sparkey
I have ordered through PLC center several times both at home and at work. They are a good company to deal with. Never had an issue with them. I don't know if they still do, but they used to throw a small bag of candy in with every order.
Cal-Redwood
Hi Lag, I check on EBay for those IO cards and could not find any sellers from US. Is there a particular link that you look for them with US seller? Thanks
lag
Middle of Iowa
I purchased Allen Bradley parts, I'm guessing more out there then omron in USA. Circuitware was one seller out of Ohio, another was Indiana surplus or something like that. It's been a couple years since I purchased anything.
I only use US sellers on used parts, because easier returns, Again I only had to return one item.
