Issues with cryptopay tap plus
RAAOO7
USA
Anyone else having issues with the new tap plus units? From some odd reason it intermittenly doesnt read/detect cards untill the power is shut off for a few seconds then turned back on. I've been having this issue since i made the switch from swipers. I also lost a few customers as well because the bay wouldnt turn on and the customer didn't have cash on hand. This is a real bummer because i spent alot of money converting to tap plus units thinking they were going to be better and easier to use for the customer. It's been turning out the opposite.
tdlconceptsllc
NC
I had this exact problem today and power cycled and everything started working wonder what happened only on the TAP mine is not the TAP plus
RAAOO7
USA
They are not giving me the correct reason why its doing this. Most likely they dont know how to correct this Bug that the units have. They will always come up with some excuse or connectivity issue but this is not the case. Some how it seems like its locking up or freezing untill you power it down then turn it back on.
RAAOO7
USA
I never had this issue with their swipers. I've been using crypto swipers for years! There's some kind of bug thats causing this issue but cryptopay can't figure it out. At $500 per unit, the device should run superior without having these type of issues.
tdlconceptsllc
NC
Today was the first time I have seen it normally they run great. Should we put a christmas tree timer on the cryptopay router to reset once a day.
