JC Shampoo
txheat
Its not foaming up like it suppose to. In the beginning, Compressor was making a lot of noise and only liquid comes out , therefore i replace the compressor. Then to find out still no air going to the gun, so replace air coil. I guess old compressor is still good, havent test it yet. Now air going to gun but still doesnt foam up. Comes out more liquid than foam. Any suggestion?
If it's anything like the Fragramatics shampooers, there should be a foam pellet in the brush head to make it foam, and that pellet disintegrates over time. I usually find a used ArmorAll sponge, make a new pellet with a gasket punch and replace it.
Coleman has some mesh material they stuff in the head to help foam. If you look in another shampoo you can see it. The closet material I have found is from a mesh "bath pouf"
