JE Adams Vac Cryptopay Swiper
Jaltavela
Hi Guys, I bought a ne JE adams triple motor to replace an older one that burned up. The old one has an IDX timer and the new one has a Zettler timer. I cannot find any wiring diagrams for the new timer. I wired it the same as the idx and it didn't work. I have a transformer for power, and then hooked the red and green pulse wires to the two coin wires. It processes the card and turns green on the swiper but will not fire the vacuum.
Wiring diagram on Page 32
If I remember right, Zettler is just a component of the timer. I think its called a "Littlefuse". JE Adams refers to that timer as "SSAC"
Again, if i remember correctly, one red/green pulse wire sits on the 110 VAC common wire and the other goes to #6 on the timer.
Edit: I'm referring to an IDX coin accepter.
Cryptopay sent me a diagram. I figured id upload it incase anyone else runs in to this problem.
