Spitfire372
How much wastewater is normal to go down the drain. Ours runs so much, and barely puts any water into the tank and the waste water line, is practically a water hose with the way the water comes out. We have checked all the lines compared it to our other RO system at the other car wash and it's all about the same, switched membranes. The only thing is the gauge is reading barely reading any pressure as our other one reads 150 lbs. Could this be affecting has the water is suppose to work in the membrane?
