Jobe Valve Topaz Float Valve Leaking
zachavm
Edmond, OK
I've got a Topaz variant Jobe Float valve that control the inlet to my hot water reservoir for my self serve bays. It is leaking and I'm not sure what to do. I bought a diaphragm rebuild assembly and it had no affect. If I need to buy a new one, I want to make sure I get one recommended by the community here. Any advice?
If you lift up on the ball does the leaking stop? Try moving the ball down a little so it puts little more pressure on the diaphragm. If that doesn't work you might have to go to another type float valve.
zachavm
Edmond, OK
Negative. Can't make it stop leaving.
