laser 4000 going long on front of cars
Mansfield ohio
Not turning properly
Goes past front of car and only stops because of stopper
Then finishes wash
And puts it's self out of order after reading car wash busy for s bit
Front eye fail error
All proxy and sensors and eyes ok
Sometimes doesn't do it on the first pass presoak
Is it the eyes on t bar
Or sensor on gantry for the flag
It lites up if I wave a wrench
And the flag is ok
MDrost1
Grand Haven, MI
If the front eyes truly do test properly, it sounds like a mid limit issue. Prox, prox wire, or flag. Just thinking out loud. Hope you figure it out.
MDrost1
Grand Haven, MI
Over length Front means:
Something is blocking the front eye. The spray arch is bent(maybe bad sheer bolt) and is blocking front measure eyes. Lastly, the front eye is bad.
Could be a wiring issue in the festoon, might need a spare wire to the front eye amp.
I am sure someone else will chime in.
Scrub Free
Seabrook
Agreed eliminate all mechanical blockage,bent sheer pin,flat tire on trolley. Then if you don't remember how old eyes are just replace them.
Mansfield ohio
its the eye on the passenger t bar
stupid thing was on then checked again it was off and could not get it back on wiggling wires
then came and went.
popped the rear eye off hooked up to front and walla now need to get an eye
all back up thanks for the quik responses
