Laser 4000 or ww high velosity overhead hose
tobaccofarmer
Ric
Cantree Member
West Michigan
I wear out the hose before I wear out the ends. Are you using a caustic pre-soak that is eating up those fittings?
tobaccofarmer
Well its the acid that eats the ends up. It even eats stainless just takes allot longer. If it isnt stainless it will disappear in a couple weeks. These hose ends were one of the last things I needed to change over.
lag
Middle of Iowa
Like Ric ,the hoses usually go first for us. a few of the swival ends have leaked from time to time. If your acid is taking out the hose ,how often are the other componets( injectors,hoses,fittings,check valves ,ect) holding out?
I have overhead hoses that have been on for years,and I do not use stainless ends.
