Laser 4000 supply tank
Mansfield ohio
Hello
my bob is not closing all the way on my fill tank.
Time to replace, i have a ss tank set above on the pump station with a bob valve with a diffuser attached to it
can u use something else like a jobe or do u need the diffuser, from what i see the jobe wont acept a diffusser
thanks
tdlconceptsllc
NC
Topaz water valve is what you need. I will look tonight if I kept the diffuser I don’t believe so the topaz allows more water GPM.
MDrost1
Grand Haven, MI
The diffuser on the outlet is necessary so the "low water cut off" switch doesn't turn on intermittently.
Mansfield ohio
Low water cut off has been retired :)
would be nice though just for turbulance and sucking air into pump
but i dont see how you put a diffuser on a topaz jobe am i missing the big elephant standing in the room
were the water comes out its like a oblong shape or is there one with a female screwin so you can attach the diffuser.
Mansfield ohio
Put a 1' topaz on there with no diffuser cause it has a oval out put and no thread to put one on as i can see
works fine for now i was worried about cavitation from the bubbles
see what happens when its really cranking
GoBuckeyes
Self-Serve and Automatics
Cleveland
I've been running the 1" Topaz for over two years now and have had no issues resulting from the lack of a diffuser. My low water cut off has also been unaffected.
