zed 9
Hello hope everyone is well,
our Laser Wash M5 the trolley / arch is going wide full extents on all passes around a car. No problems measuring the lengths.
Regarding the side ultrasonics and in Auto mode should i hear them "ticking "?? I only hear the "ticking " in Maintenance Mode, is this correct or is there something wrong.
I have installed two new side ultrasonics but the trolley / arch still goes too wide, and carried out a Run ( test 0 ) to detect the presence of all flags and Run ( Test 2 ) run the trolley left - right and the bridge front- back several times. My numbers for the trolley encoder left to right are within 3 of each other and the bridge encoder back numbers is 205 and the front is 231.
I have carried out Config 5 Test, the bridge moves 5 times front and back, the trolley moved to the center of the bridge and the machine enunciates High Limit repeatedly.
Does anyone have any thoughts or ideas of what is causing the trolley / arch to go wide.
Best regards
zed9
Best regards
zed9
