zachavm
I would like some help with my programming for our Laserwash 4000. I want to make sure it is set up correctly. The settings are using the following chemicals from Lustra:
Low Press Soap 1238 The Option
Low Press Soap 2 1238 The Option
Foaming Wax 2551 Low pH Polish Raspberry
HP Polysealant 2406 ProShield Pina Colada
HP Drying Agent 2303 Dri-Max
The main thing I'm concerned with is the order of everything. I've seen people suggest different orders for the drying agent, polysealant, spot free rinse.
Also, are there better options for the presoak? Seems weird to use the same chemical for a two step process.
Code:
CONFIGURATION REPORT
PDQ LASERMIND
By PDQ Manufacturing
Version 20.0.c
Unit # 0000
Tue 04/23/19 18:18
Systm Temp 78 F Bay Temp 54 F
Soap Temp 66 F
PRICES
Wash 1 Price $ 06.00
Wash 2 Price $ 07.00
Wash 3 Price $ 08.00
Wash 4 Price $ 09.00
CYCLES
WASH 1
Undercarriage Spray OFF
Soap Type: Disabled
Dryer ON
Bug Prep OFF
Rear Bug Pass OFF
Cycle 1 Low Press Soap Speed-5
Cycle 2 Disabled
Cycle 3 Soaking
Cycle 4 High Press Rinse Speed-3
Cycle 5 Spot Free Rinse Speed-6
Cycle 6 Disabled
Cycle 7 Disabled
Cycle 8 Disabled
Cycle 9 Disabled
WASH 2
Soap Type: Disabled
Dryer ON
Bug Prep ON
Rear Bug Pass OFF
Cycle 2 Low Press Soap 2 Speed-7
Cycle 3 Soaking
Cycle 5 HP Polysealant Speed-7
Cycle 6 Spot Free Rinse Speed-6
Cycle 7 Disabled
Cycle 8 Disabled
Cycle 9 Disabled
WASH 3
Undercarriage Spray ON
Soap Type: High Press Rinse
Dryer ON
Bug Prep ON
Rear Bug Pass OFF
Cycle 3 Soaking
Cycle 5 Disabled
Cycle 6 HP Polysealant Speed-7
Cycle 7 HP Drying Agent Speed-7
Cycle 8 Spot Free Rinse Speed-6
Cycle 9 Disabled
WASH 4
Dryer ON
Bug Prep ON
Rear Bug Pass ON
Cycle 3 Soaking
Cycle 5 Foaming Wax Speed-5
Cycle 9 Disabled
Automatic Options
Entrance Timer 120 secs
Undercar Spray Timer 30 secs
Soaking Timer 05 secs
Drying Timer 45 secs
Driveoff Timer 050 secs
Stuck in Bay Timer 075 secs
Arch Dump Timer 003 secs
Hi Pres Delay Timer 03 secs
Hi Pres Poly Delay Timer 04 secs
Low Press Delay Timer 3 secs
Soap Temp Set Pt. 033 degs
Rail Heat-On Temp 36 degs
Weep Turn-On Temp 00 degs
Weep Mode CYCLED
Width Measure Adjustment 3
Length Measure Adjustment 6
Service Sign Flash OFF
PLUMBING CONFIGURATION NUMBER
004
SYSTEM OPTIONS NUMBER
00544385
Program Mode Exited
Tue 04/23/19 18:18
