1carwash1
I have some older Erie 3 way diverter valves that control the flow of either hot or cold water to the hi pressure pumps (rinse, wash, & wax) that are starting to leak where the shaft comes through the valve body to connect to the actuator motor. I need to replace these and wonder if there was a better alternative such as 3 way solenoid valves or motorized ball valves, etc. Thanks in advance for your help.
