Led-7 and Cryptopay
ronswash
Circleville Ohio
I finally have everything I need for my install. My question on the dixmor led-7 it said to short out pin 9 to pin 6. Do you leave the two connected? Also I have securecoin coin acceptor shouldn't I use the red wire (signal-AC) from the swiper and where do I connect it to? I must have too many irons in the fire to be asking these question. Thanks in advance!
In 3 of my bays I have bill acceptors and I'm sure I'll be asking questions about what I'll need to do if anything to hook them up.
You’re making this harder than it really is. Connect the Black wire from the swiper to your 24 volt common, connect the Yellow wire from the swiper to the 24 volt hot. The Red from the swiper gets connected to the white wire with the black tracer that comes from pin #9 on the timer. Your timer software should be version 7.36. On your bill validators the pulse wire from the bill validator gets connected to the Yellow wire with the black tracer that comes from pin #8. Your common and hot wires to common and hot inside the coin box.
Lexington, Ky.
"My question on the dixmor led-7 it said to short out pin 9 to pin 6." This was confusing to me at first as well. I called Dixmor and basically the Cryptopay swiper is doing this for you, so you just wire it normally and you don't have to short or jump any pins.
ronswash
Circleville Ohio
It turned out that I did need to use the blue wire and not the red. All bays seemed to work ok. Thanks again.
Lexington, Ky.
Glad to hear it's working. The blue wire is for a dedicated credit card input, the red wire is used for timers other than Dixmor or when count down is used.
