washnshine
I operate a short tunnel - 1 overhead wheel, 1 set of wraps, 1 set of rockers - all foam, except for cloth on the rockers. I use a neutral body and lubricating soap and have good results cleaning and drying - no quality issues at this time. We do manually prep with a higher pH solution for bugs on the front ends.
I've read that low pH wash detergents can be advantageous and are designed for a shorter wash. What advantages could I expect from using this type of detergent versus a neutral detergent?
My foaming polish and protectant are neutral as well - only thing that is not is the wheel cleaner.
Thanks.
Thanks.
